-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   setting the timing on an r56 (http://forums.pelicanparts.com/mini-discussion-forum/933900-setting-timing-r56.html)
bigwull 10-29-2016 08:42 AM
hi when you set the timing marks on the camshafts inlet & exhaust does the locking pin on the crankshaft go right in to the end of the pin thanks bigwull
Luccia at Pelican Parts 10-31-2016 10:07 AM
Welcome to the Pelican MINI community, bigwull.
Have you taken a look at our timing chain tech article?
MINI Cooper R56 Turbocharged Engine Timing Chain Guides Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
If that does not help please scroll to the bottom of the article where it says "comments & suggestions" and post a reply with your specific inquiry. Nick should come back and answer it with specifics. Let me know if you have any questions about that.
