-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Battery and Connection Notes Replacement (http://forums.pelicanparts.com/mini-discussion-forum/934631-question-battery-connection-notes-replacement.html)
Barsadave (guest) 11-04-2016 11:20 AM
I am just removing the battery for winter storage so other than charging it up in the spring all should be fine to just install and go maybe other than the radio presets? Thanks
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Battery and Connection Notes Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 11-04-2016 11:20 AM
Yes, should be fine.
- Nick
Luccia at Pelican Parts 11-07-2016 10:45 AM
Why not just connect it to a battery tender instead of removing it and then having to worry about reprogramming your radio, etc? This is the route I would go. The single charging units are fairly inexpensive, $50, and give you ease of mind that you aren't wasting a perfectly good battery.
Battery Tenders here: Mini Cooper, Cooper S, and Clubman (R55/R56/R57) - Miscellaneous - Page 11
Also, since you're storing your MINI (assuming in a garage) might also want to check out our GarageGaurd here: http://www.pelicanparts.com/catalog/coverking/coverking_garageguard.htm. Let me know if you have any questions.
