Think I need a new reservoir... I pressurized the reservoir with brake bleeder pump, it reached about 10 psi and fluid was everywhere. I can't tell where it coming from but I'm guessing around the seams on the back side. What part are needed to complete this job other than reservoir? How do I disconnect the clutch line and reattach? Thanks!
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Brake Master Cylinder Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article |
The reservoir may be available. Give The Pelican Parts parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick |
| All times are GMT -8. The time now is 01:16 AM. |
