R56 fault codes 2D60, 2C58 & reduced power
I have a 2012 Mini Cooper Hardtop R56S and i lately have been getting codes 2D60 & 2C58. The check engine display with half illuminated, not in RED, comes on also. What could be the problem.
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 VANOS Solenoid Replacement (2007-2011) | Pelican Parts DIY Maintenance Article |
Do you have the fault code descriptions? Could be engine misfire.
- Nick |
Those are the MINI FC codes. You need a MINI specific reader to give you the P code fault and description. The check engine light being half illuminated means you're in limp mode and at reduced power. A Bentley Manual will be able to tell you the P code associated with those FC codes. I suggest you pick one up here: 2012 Mini Cooper S Hatchback - Books & Technical Documentation - Page 1. Until we figure out the true P code we wont know what to fix/replace.
0x2D60 is P0265 Cylinder 2 injector circuit high Info here: http://www.autocodes.com/p0265_mini.html Everything points to clogged fuel injector(s). Recommend running some 44k BG into your gas tank. If it's a bad fuel injector we have this article here: http://www.pelicanparts.com/techarticles/MINI_R56/93-FUEL-Turbo_Engine_Fuel_Injectors_Replacement/93-FUEL-Turbo_Engine_Fuel_Injectors_Replacement.htm. 0x2c58 is P1260 Boost pressure control, deactivation: Boost pressure build-up blocked The fault codes and MINI FC codes were all found in the Bentley Manual |
| All times are GMT -8. The time now is 04:52 AM. |
