-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Rear Wiper Arm and Motor Replacement (http://forums.pelicanparts.com/mini-discussion-forum/939115-question-rear-wiper-arm-motor-replacement.html)
Bob (guest) 12-13-2016 10:39 AM
2002 Mini Cooper S: Can I purchase the pipe that feeds the windshield wiper fluid through the rear winshield wiper assembly and the windshield wiper secures to it with the nut? Mine was clogged and after cleaning it out it leaks, I believe that corrosion ate away at the ball metal where the sprayer connects to it.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Rear Wiper Arm and Motor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 12-13-2016 10:39 AM
It should be available. Give The Pelican Parts parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
Luccia at Pelican Parts 12-20-2016 11:23 AM
Ask for Mike S. he can help you. Make sure you have the last 7 digits of your vin.
