-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Turbocharged Engine Thermostat Replacement (http://forums.pelicanparts.com/mini-discussion-forum/939435-question-turbocharged-engine-thermostat-replacement.html)
Back street garden mechanic (guest) 12-16-2016 03:12 AM
Hi guys. Just replaced my wife's 2007 cooper R56 thermostat . Thanks to your directions! After 3 days had a new error code: $7E8 engine, as well as : $79 A/T. When I clicked on these it stated "Engine coolant temp sensor 1",and "circuit low". But after many hrs on the web, nothing. Any ideas?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Turbocharged Engine Thermostat Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 12-16-2016 03:12 AM
Check if the sensor was damaged during the thermostat repair. http://www.pelicanparts.com/techarticles/MINI_R56/86-ENGINE-Coolant_Temperature_and_Oil_Pressure_Sensor_Replac ement/86-ENGINE-Coolant_Temperature_and_Oil_Pressure_Sensor_Replac ement.htm
- Nick
Luccia at Pelican Parts 12-22-2016 09:42 AM
Make sure you have the connectors plugged into the right connections. Some individuals get the swapped, which will trigger a CTS fault code. Make sure the connections are also not loose/damaged.
