-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Constant P0301 code (http://forums.pelicanparts.com/mini-discussion-forum/942827-constant-p0301-code.html)
Eurotech (guest) 01-18-2017 06:47 AM
Constant P0301 code
2010 mini clubman non-s N12 engine compression test numbers were around 165psi for cylinder #1 and the others were within 10psi of each other... injectors were swapped and misfire did not follow. The VANOS installed in the vehicle are the new design and not clogged, I recently acquired the vehicle with this problem so I don't know it's past. The parts I replaced are ignition coils, spark plugs all mini original dealer parts. I swapped both cam sensors and only one VANOS solonoid with ones from a 2011 mini cooper that runs and drives without faults. I'm only getting P0301 with a generic scanner but with ISTA/D I'm getting cylinder 1 misfire and random cylinder misfire. I've tested VANOS and everything reaches its set points and passes test plans.... no leak down test performed..... if I disconnect any cam sensor or VANOS electrical connector the car hiccups and then runs normal, the engine no longer misfires as viewed from misfire status..... any ideas?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Camshaft Position Sensor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 01-18-2017 06:47 AM
10 PSI difference is too much, 5 is the max you want. If one cylinder is high, there may be an issue with the exhaust valve.
- Nick
Eurotech (guest) 01-25-2017 12:46 PM
Compression results engine warm - cylinder 1 - 167psi.....cylinder 2 - 175psi ... cylinder 3 - 167psi..... cylinder 4 - 170psi.... if it is a bad exhaust valve why when I unplug any of the cam sensors electrical connectors or VANOS electrical connectors the car hiccups and then runs misfire free? Of course it throws a CEL for the unplugged sensor connector but the vehicle drives misfire free.
Nick at Pelican Parts 01-25-2017 12:46 PM
Compression is not good. You may have a base engine issue. Too much variation in results.
- Nick
