-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Alternator Replacement (http://forums.pelicanparts.com/mini-discussion-forum/943660-question-alternator-replacement.html)
hoodmeister (guest) 01-25-2017 12:44 PM
Removed the alternator to do the SC oil change and am finding that the clearance holes for mounting the alternator allow lots of slop. How does one verify that the alternator is aligned relative to the other pulleys? Just eyeball it? It would be very easy to get it pretty far off if you're not careful. Any tips? Thanks
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Alternator Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 01-25-2017 12:44 PM
Hand tighten all three fasteners before the final tighten. Check that the pulley is aligned with the crank pulley. Then tighten to final torque.
- Nick
