-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   What fails inside the HPFP? (http://forums.pelicanparts.com/mini-discussion-forum/943757-what-fails-inside-hpfp.html)
jactommac (guest) 01-26-2017 07:57 AM
what is it exactly that fails with this pump? is it a possibility to rebuild the pump?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 High Pressure Fuel Pump Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 01-26-2017 07:57 AM
The internals wear out, assuming the impeller. Ca't be rebuilt. No parts available.
- Nick
Luccia at Pelican Parts 01-26-2017 08:38 AM
The problem with the Mini Cooper S High Pressure fuel pump failing is an internal non return valve which fails and allows pressurized fuel to leak back into the fuel tank and as a result upon start-up has a lack of sufficient fuel to the injectors causing misfiring until the pump has built up sufficient pressure.
Source HERE
There are no aftermarket/performance type replacements nor any type of rebuild kits on the market. You may have some luck finding a used one on MINI forums. You can also attempt to see if your MINI qualifies for the extended warranty on the HPFP. Call your local dealer with you vin and they should tell you. Otherwise, I have posted a link to them below:
Mini Cooper, Cooper S, and Clubman (R55/R56/R57) - Fuel System - Page 2
Do note: N14 and N18 HPFP part numbers vary so if you need help with one for yours please let me know your specific R56 model and last 7 digits of your vin.
