-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Turbocharged Engine Timing Chain Guides Replacement (http://forums.pelicanparts.com/mini-discussion-forum/944980-question-turbocharged-engine-timing-chain-guides-replacement.html)
kabjamison (guest) 02-06-2017 06:29 AM
Can you use a 30mm wrench instead of the special tool 11 9 280? Some of your tech articles on crankshaft adjustment are shown a 30mm wrench.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Turbocharged Engine Timing Chain Guides Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 02-06-2017 06:29 AM
No, that tool bolts to the crankshaft hub to hold it. You will need it.
- Nick
Luccia at Pelican Parts 02-07-2017 08:02 AM
All the tools are listed at the bottom of the article before the figures. You can also see if you can rent a tool kit or borrow one from a friend.
