Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Cruz (guest)
Guest
Posts: n/a
Hi Soory my Mini is 2009 normal not "S', hope to have your valuable comments soon
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 VANOS Solenoid Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 02-07-2017, 12:11 PM
Yes That is a very common failure. To make sure that you get the right part make sure to give our parts specialists a call 888-280-7799
- Casey
Cruz (guest)
Guest
Posts: n/a
My Mini 2209 N14 motor shows a problem with the in take and out of solenoid, can this problem affect the timing change ? Can the solenoid both can be easy be clean ? if not what is the price of each.
Old 02-07-2017, 12:12 PM
See answer to your other question
- Casey
Administrator
Luccia at Pelican Parts's Avatar
The VANOS sensor for your R56 is here: 2009 Mini Cooper Base Hatchback - Cylinder Head & Valvetrain - Page 4.
Old 02-08-2017, 08:45 AM
