-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Turbocharged Engine Timing Chain Guides Replacement (http://forums.pelicanparts.com/mini-discussion-forum/945377-question-turbocharged-engine-timing-chain-guides-replacement.html)
Mike (guest) 02-09-2017 05:18 AM
Installing a timing chain tension bolt on an 2007 R56 mini turbo...but the chain is so tight the guide rail will not move in for me to put the tension bolt in.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Turbocharged Engine Timing Chain Guides Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 02-09-2017 05:18 AM
You will have to push the tensioner in as you thread it in. That is the only way, the engine or timing chain can not be moved once the tensioner is removed.
If too tight, you may not have set the engine to TDC before removing.
- Nick
