Hello, Please help. My daughter has a 2003 mini cooper R50. The shift cables are bad and need replaced. I was told that there are two types of shifters used in the car and that the cables I need are based on the shifter housing. The housing either has three grooves or is smooth. There is no way to view the external portion of the shift housing without removal. Is there a way to determine which housing is used and what cables are required without removing the housing?
http://www.pelicanparts.com/more_inf...536-154404.jpg __________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Shift Cable Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article |
See answer to other question.
- Casey |
Hello, I found that the shift is version 'A' shifter with 3 ridgeshow do I go about ordering the correct cables?
25-11-7-515-455-BOE
25-11-7-515-456-BOE - Casey |
| All times are GMT -8. The time now is 01:54 AM. |
