-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Turbocharger Wastegate Testing (http://forums.pelicanparts.com/mini-discussion-forum/945879-question-turbocharger-wastegate-testing.html)
Chadder (guest) 02-13-2017 10:58 AM
I am experiencing similar problems to a previous thread MCS od JCW, code 2C57. I've replaced the diverter valve to no avail. The thread does not come to a conclusion. I've applied vacuum to my wastegate and it functions smoothly. Is my next move to check the wastegate? Is there anything aftermarket to cure this? 2012 N18 with 85K.
This post was auto-generated based upon a question asked on our tech article page here: Mini R56 Testing the Engine Turbocharger Wastegate | R56 Cooper S Hatchback (2007-2013), R56 Cooper JCW Hatchback (2009-2013) | Pelican Parts DIY Maintenance Article
Casey at Pelican Parts 02-13-2017 10:58 AM
I have seen faulty turbocharger cause that fault if the diverter is OK.
- Casey
Luccia at Pelican Parts 02-14-2017 07:29 AM
Is this the thread you're talking about? http://forums.pelicanparts.com/bmw-mini/927923-fault-code-2c57.html
Did you check the Pressure Converter?
Yes, test the wastegate using this article: Mini R56 Testing the Engine Turbocharger Wastegate | Pelican Parts DIY Maintenance Article.
