-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Power Steering Pump Replacement (http://forums.pelicanparts.com/mini-discussion-forum/946247-question-power-steering-pump-replacement.html)
jjb (guest) 02-16-2017 09:22 AM
hello, im trying to find a 10% definate answer.
i need to replace my 2002 r53 mini cooper s , steering pump. now i can get a used one with the number the same as in your pictures 7625477132, will this fit?? thank you inm advance
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Power Steering Pump Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Casey at Pelican Parts 02-16-2017 09:22 AM
That is not a good number. I show 32-41-6-778-425-M1314 being the correct part.
- Casey
Luccia at Pelican Parts 02-16-2017 12:10 PM
Posting the last 7 digits of your vin number will also help confirm. 7625477132 does not pull up anything in real OEM's database. Are you sure that is the correct part number?
We have rebuilt units here: 2002 Mini Cooper S Hatchback - Steering System - Page 1
Did you first contact your dealer to see if you qualify for the extended warranty on them?
jjbbuzz 02-23-2017 03:35 AM
7625477132 was a number I took from sticker on actual steering pump?
Luccia at Pelican Parts 02-23-2017 07:05 AM
The power steering number you'll want to use for your R53 is 32416778425 as shown below on the diagram.
http://forums.pelicanparts.com/uploa...1487865909.png
