-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   P2096 keeps coming back (http://forums.pelicanparts.com/mini-discussion-forum/946248-p2096-keeps-coming-back.html)
DKM (guest) 02-16-2017 09:24 AM
Replaced the cat, new O2 sensors SES light remains on ... ðŸË?¡ Any suggestions? My OBDI is not clearing any codes ...
This post was auto-generated based upon a question asked on our tech article page here: Mini R53 Catalytic Convertor Replacement | R53 Cooper (2002-2006) | Pelican Parts DIY Maintenance Article
Casey at Pelican Parts 02-16-2017 09:24 AM
Not sure but I think there may be a software fix for that.
- Casey
Luccia at Pelican Parts 02-16-2017 12:07 PM
Has your OBDII diagnostic scanner been able to clear codes before? If you're unsure, bring it by a MINI indy shop and they can clear the codes for you for a small fee. You have have BMW specific codes that require a BMW specific scanner to clear them.
Also, why did you replace the cat and O2 sensor in the first place? Did you have codes that pointed to them as the issue for your SES light?
DKM (guest) 02-17-2017 08:13 AM
I used the Shark purchased here to reset the code and restore to stock - light went off. Came back on on second start ... code is 2096
Casey at Pelican Parts 02-17-2017 08:13 AM
Use a smoke machine to fill the exhaust system with smoke and look for leakage, I have only seen exhaust leaks cause this fault. Now knowing that you've replaced the cat and O2's I would start looking for a lean condition, check fuel trims are they indicating a lean condition? Double check all your exhaust connections and if you find the fuel trims are indicating a lean condition check intake system for leaks especially around the supercharger air inlet. Check Fuel pressure.
- Casey
Luccia at Pelican Parts 02-20-2017 07:59 AM
Depending on the MINI FC code, you could have a too lean condition. Assuming what code you posted is P2096. As Casey said, perform a smoke test. A local indy shop can do this for you.
