Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Rui (guest)
Guest
Posts: n/a
When car is off I can change all gears but soon I start the car can't put first or reverse unless I turn off the car.When driving is getting difficult to change gears but I can do it and without any grinding noise.I have a new clutch slave.Can you give me your opinion about this problem?Thanks!
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Manual Transmission and Differential Fluid Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 02-23-2017, 10:46 AM
That's a good start replacing the slave, but I have also seen a bad clutch and flywheel cause this issue.
- Casey
Administrator
Luccia at Pelican Parts's Avatar
If it ends up being a clutch issue we have some really great clutch super kits here: Mini Cooper & Cooper S (R50/R52/R53) - Clutch & Flywheel - Page 1 that have just about everything you'll want to replace while you're in there for the job.
Old 02-28-2017, 10:55 AM
