I have a 08 mini s r56. I was wondering would remedy the issue with the automatic trans. Its seems to be not cathing 4th or 5th gear very well. It tends to hard babg when i let off the accelerator and have it catch. I was wondering if the drain and fill could help seeing as it hasnt been done the vehicle is at 110k now.
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Automatic Transmission Fluid Change (R50/R52/R53/R56/R57 2001-2015) | Pelican Parts DIY Maintenance Article |
Sounds to me like a low fluid level condition. Go ahead and try to top it off first, if that helps perform the drain and refill.
- Casey |
| All times are GMT -8. The time now is 05:44 AM. |
