P1434 error code
Have a check engine ight and getting a P1434 error code.
Reference says this: P1434 - DMTL Tank Leakage (Diagnostic Module Tank Leakage) P1434 - DMTL, system fault: Abort due to current fluctuations during reference measurement Doesn't say current is high or low. That would be a different code. Should I assume the pump is bad and change it? In the meantime can I keep driving it? Thanks. |
What year and model MINI do you have?
Luccia,
Its a 2010 Coupe. I checked and tightened the gas cap, cleared the error and it has so far not reappeared. I am crossing my fingers that it won't come back but I wanted to thank you for the offer to help. Matt |
Matt - I have seen both issues - a loose gas cap or a faulty DMTL pump. To be safe check the seals on your gas tank cap as well to make sure that it isn't broken, causing a poor seal when you tighten the cap. Let's hope your issue is not a faulty DMTL pump.
Here are great descriptions of the codes you received: P1434 MINI FC (0x2736) - Detection Module for Tank Leakage [DMTL] - Tank Leakage P1434 MINI FC (0x3220) - DMTL, System Fault - Abort Due to Current Fluctuations during Reference Measurement Quote:
so I'm having the same issue, but I've already changed my had cap, cleared code and eventually it came back on 08 r56 base. any idea?
Next step is to look into a faulty DMTL pump.
| All times are GMT -8. The time now is 03:21 PM. |
