I have an '09 Mini JCS Clubman. The left front cv axle is bad. It is absolutely stuck in the hub. I've used pullers and heat...it's not budging. Not worried about damaging the existing axle since it's already bad anyway, but do you have any suggestions?
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Drive Axle Replacement (2007-2011) | Pelican Parts DIY Maintenance Article |
Remove it with the bearing, then replace the axle and bearing.
- Nick |
Is your Clubman a JCW or Clubman Cooper S? There is no such thing as a JCS. Just want to make sure, but it looks like the part numbers are the same for the Cooper S and JCW:
Wheel bearing (comes with new hub): 2009 Mini Cooper S Clubman Wagon - Axles, Bearings & Differential - Page 3 |
| All times are GMT -8. The time now is 12:39 PM. |
