-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Fuel Rail Pressure Sensor Replacement (http://forums.pelicanparts.com/mini-discussion-forum/948664-question-fuel-rail-pressure-sensor-replacement.html)
tooltimeguy (guest) 03-08-2017 04:26 AM
Can a dirty fuel filter cause the fuel pressure sensor to set the MIL? Under heavy acceleration I get a check engine light however my reader says there is no code set. Never the less it clears the code. The engine light stays off unless under heavy acceleration.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Fuel Rail Pressure Sensor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 03-08-2017 04:26 AM
Not unless fuel flow was greatly reduced. Check pressure, volume and fuel quality to be sure.
- Nick
Luccia at Pelican Parts 03-08-2017 09:56 AM
You might have a dealer level code being triggered that your reader wont be able to read. Might want to swing by a MINI indy shop and see if they can pull a code with theirs. Any other symptoms other than the CEL? What routine maintenance services have you done recently?
