how to fix my code P0014 on my 2007 mini cooper
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 VANOS Solenoid Replacement (2007-2011) | Pelican Parts DIY Maintenance Article |
Check the article you commented on. If that doesn't do it, check mechanical engine timing.
- Nick |
P0014 - "B" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
Do you have hard starts or poor idling? Yes, attempt to remove the exhaust VANOS solenoid and checking if it is gunked up and clean it. You can also attempt to swap your intake camshaft sensor with the exhaust camshaft. See if it changes. If cleaning does nothing, replace it. Updated part here from MINI: 2007 Mini Cooper Base Hatchback - VANOS Solenoid |
| All times are GMT -8. The time now is 04:51 AM. |
