-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Manual Transmission Oil Change (http://forums.pelicanparts.com/mini-discussion-forum/949738-question-manual-transmission-oil-change.html)
Danny (guest) 03-16-2017 01:55 PM
when we are changing the clutch and installing a quaife differential, can we just fill up the case with transmission fluid before we put it back on the car?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Manual Transmission and Differential Fluid Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Casey at Pelican Parts 03-16-2017 01:55 PM
Sure, just double check the fluid level again after it is bolted up.
- Casey
