Getting a oil warning light after 10-15 mins of driving and only after I've come to a stop light or sign. Have replaced the turbo recently with a stock replacement as it blew a seal while driving and the oil pressure sensor. 2 shops have said the oil pump is good. Any idea? 2009 MCS.
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Coolant Temperature and Oil Pressure Sensor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article |
If the oil pump is good, then you have a faulty oil pressure switch or a restriction causing a pressure drop at the switch. I would monitor pressure when the problem is present and see if it does inf act drop.
- Nick |
Dumb question time:
How's the oil level? I know mine is a pain in the tail to read... --DD |
| All times are GMT -8. The time now is 04:09 PM. |
