Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
mike (guest)
Guest
Posts: n/a
Did a favor for Wife's co-worker. Removed his blown rod through block JCW motor from his 2008 and sourced a 2006 JCW motor used 98k. I went through the used motor t-chain set, seals, hoses, t-stat, etc.... The motor sounds great, fired right up but I am pouring Blue smoke oil smell out the exhaust. Car runs at middle of temp range. No noises from engine. I did use the better looking Valve cover off old motor. Can a valve cover PCV system cause this?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Valve Cover Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 03-28-2017, 01:45 PM
Yes, also if the car was blowing oil into the cat, it may take a while for all the residual oil to burn out of the exhaust, make sure this is new oil smoke, and not old oil smoke.
- Casey
Administrator
Luccia at Pelican Parts's Avatar
Since they blew the block, I wouldn't be surprised if there is residual oil in components, including the exhaust. I'd take it off and see if you can clean as much of it out as you can.
This article can help with the removal: MINI Cooper R56 Exhaust System Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 03-29-2017, 09:45 AM
