Does my car need the battery registered if my does not have IBS?
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Battery and Connection Notes Replacement (2007-2011) | Pelican Parts DIY Maintenance Article |
I believe so.
- Casey |
Dave - check your negative terminal. Look at the purple arrow below. Does it have this unit on there? If you're unsure, please post an image and I can tell you if you have an IBS unit. If it does, you should register the battery. It can be easily done by using the iCarly App if you do not have a scan tool.
http://cdn4.pelicanparts.com/techart...mall/pic03.jpg |
| All times are GMT -8. The time now is 08:21 PM. |
