Guest
Posts: n/a
R50/R53 rear spoiler removal
How do you replace the third brake light on an 06 mini cooper with original factory spoiler? Seems spoiler is glued down an in the way of removal of the assembly. Do not want to damage good paint and no leaks in rear.
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Lens and Bulb Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article |
I am not sure, I will post this to the forums and see if another member can offer guidance.
- Casey |
Administrator
I believe there are two bolts and two adhesive pads on each side of the spoiler. You can take a blow drier to it with some floss to remove it the adhesive. This image may help:
![]() Last edited by Luccia at Pelican Parts; 03-30-2017 at 09:04 AM.. |
