Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Nico Cetti (guest)
Guest
Posts: n/a
Hi, I've replaced my HPFP as I had slightly low pressure. Pressure now seems ok, however the fuel volume control valve keeps fluctuating between 0-30% and is effecting my idle timing. Sometimes it sits at 12% and idles fine, but most of the time its random. Where is this valve located? Thanks in advance.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Fuel Rail Pressure Sensor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 04-05-2017, 11:46 AM
High-Pressure Pump 13517588879 - Genuine MINI - BMW - 13-51-7-588-879 | Pelican Parts ] High-Pressure Pump 13517588879 - Genuine MINI - BMW - 13-51-7-588-879 | Pelican Parts [/url] You can see it in the photo, it is the electrical connector and solenoid on the top of the pump.
- Casey
