Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Ghost mini (guest)
Guest
Posts: n/a
I have a 2009 Mini Cooper base with p0014 code have changed both vanished selanoids and both cam sensors and still have the same code after clearing multiple times please help
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Valvetronic Faults (2007-2011) | Pelican Parts DIY Maintenance Article
Old 04-05-2017, 09:53 AM
Verify that your oil level is topped up to MAX, and also that your oil is fresh. Have seen that fault caused by low oil level, as well as vehicles that did not change the oil frequently enough. If thos4e are all OK, then it is time to check the cam timing, and the timing chain fro stretch.
- Casey
Administrator
Luccia at Pelican Parts's Avatar
If you replaced all those components I'd think it has to do with your timing possibly being off.
Code P0014 "B" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
Old 04-06-2017, 10:11 AM
