-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Spark Plugs and Cable Replacement (http://forums.pelicanparts.com/mini-discussion-forum/952225-question-spark-plugs-cable-replacement.html)
Kevinj (guest) 04-05-2017 11:42 AM
Changed the spark plugs on my 2010 mini clubman s. engine started fine. Reconnected a ground that had come loose and now it won't start. The engine turns over fine but there is no spark so I'm not sure what is going on. Please help.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Spark Plug and Cable Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Casey at Pelican Parts 04-05-2017 11:42 AM
You should check the system for any faults. My guess is something needs to be reset using the scanner.
- Casey
Luccia at Pelican Parts 04-06-2017 09:43 AM
Make sure the connections on the battery terminals are not loose. Definitely plug into the DME and check for faults.
