-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Turbocharger Replacement (http://forums.pelicanparts.com/mini-discussion-forum/952227-question-turbocharger-replacement.html)
Cris H (guest) 04-05-2017 11:43 AM
First of all, thanks for the tech articles. I just replaced the turbo on my sons 07. Dealer said the waste gate was causing a reduced performance code, not detected on the obd II, of course. Bought a borg replacement. Now we have very little boost. After running for 10 minutes including a short drive, cleared the obd II and no the car won't run. Any ideas?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Turbocharger Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Casey at Pelican Parts 04-05-2017 11:43 AM
Maybe a restricted catalytic converter?
- Casey
Luccia at Pelican Parts 04-06-2017 09:39 AM
Has the CEL come back on or any codes in the system since you cleared it and drove it? I'd go over everything and make sure you installed everything back where it needs to be. Check for vacuum leaks. To make sure we don't have 2 problems at foot here, check the battery voltage. Make sure the connection on the battery terminals is not loose. This will cause a no start.
MINI Cooper R56 Battery and Connection Notes Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
