Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Marcelo (guest)
Guest
Posts: n/a
R56 N18 valve cover membrane replacement?
One help from the experts, please. =]
My car is a Cooper S 2012 Gen R56 Engine N18
How can I take off the left-upper covering for the valve crankcase membrane/ventilation.
I have a new membrane to replacement, but I can't take the cover off. No matter how much force I apply. If I pull from the left-top to the right I can hear the pop sound of the clip, but the rest of the piece stills stuck. I believe there is some trick to remove the rest.
This is a common issue. I read in many foruns users that got that membrane teared. The Mini dealer solution is replace all valve cover. But there is no need if only the membrane is gone, right? =/
Could you help with this?
I've attached a self explanatory photo.
thanks!
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Engine and Transmission Mount Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 04-19-2017, 07:32 AM
Nick at Pelican Parts's Avatar
You have to replace the cover. Most times these break when trying to service. Some don't come apart. it is a dice roll. MINI states replace valve cover as unit. Give The Pelican Parts parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
Valve cover for your R56 is here: Valve Cover 11127646552 - Genuine MINI - BMW - 11-12-7-646-552 | Pelican Parts.
Old 04-19-2017, 11:47 AM
