-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Camshaft Sensor Replacement (http://forums.pelicanparts.com/mini-discussion-forum/953833-question-camshaft-sensor-replacement.html)
Sandra (guest) 04-19-2017 07:14 AM
Hi, diagnostics machine says the cam belt sensors need replacing. Should they both be fine at the same time?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Camshaft Sensor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 04-19-2017 07:14 AM
I would replace as a set. When one goes bad, the other usually isn't far behind.
- Nick
