I replaced everything but the window no longer operates with the two step seal process. It still takes to clicks to open the door but the window doesn't move. What part of the mechanism might be out of place that doesn't release the window?
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Window Regulator Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article |
Did you relearn the adaptation?
- Nick |
I don't know what you mean by 'relearn the adaptation. Where do I find information on this procedure?
MINI Cooper Window Regulator Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article In the article above you want to review figure 38, 39 and 40 for these adjustment steps. When you finished the install, with the door completely closed you'll want to make sure to lower and raise the window completely. Then, when the window is fully raised, hold the switch in the up position for 10 seconds. This reprograms the GWC. |
| All times are GMT -8. The time now is 12:50 AM. |
