Get cel code p0342 inlet phase reference could this just be inlet cam sensor?
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Camshaft Sensor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article |
Yes, most likely just the sensor. Give The Pelican Parts parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick |
Depending on the MINI FC code, this is what that P code indicates:
P0342 0x2983 Camshaft Position Sensor 'A' Circuit Low (Bank 1) P0342 0x300D Intake camshaft position sensor: Signal too low You can test your sensor before replacing it to be sure. Use this article: MINI Cooper R56 Camshaft Position Sensor Testing (2007-2011) | Pelican Parts DIY Maintenance Article. |
| All times are GMT -8. The time now is 05:21 AM. |
