-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Clutch Replacing (http://forums.pelicanparts.com/mini-discussion-forum/957769-question-clutch-replacing.html)
joe highway (guest) 05-24-2017 08:11 AM
Re: Clutch Replacement.
Pretty good directions that is up and until I attempted to remove the transmission. Try as you might, it is impossible to remove the transmission without also dropping the sub frame and there were no directions for that here. Took a bit of thought and injenuity, but its done! Oh, mine is a 2007 56R. Please update article and it would be great.
This post was auto-generated based upon a question asked on our tech article page here: Mini R56 Clutch Replacement | R56 Cooper (2007-2013) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 05-24-2017 08:11 AM
Figure 10 notes to remove it.
Remove the drive axles. See our tech article on drive axle removing. Remove subframe. See our tech article on subframe removing.
Large Image | Extra-Large Image
- Nick
Luccia at Pelican Parts 06-09-2017 09:46 AM
Axles MINI Cooper R56 Drive Axle Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Subframe MINI Cooper Subframe Removal (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
