How can you determine when the rear shocks should be replaced?
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Rear Shock and Spring Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article |
if leaking, high mileage for preventive, or if the rear end has excessive bounce.
- Nick |
You might also hear a clunking type sound from the rear. It'll definitely be a bit more of a bump and most certainly feel like a much harsher ride. If you're replacing your shocks you'll also want to replace your shock mounts while you're in there.
Mini Cooper & Cooper S (R50/R52/R53) - Suspension, Shocks & Springs - Page 3 |
| All times are GMT -8. The time now is 09:19 PM. |
