2009 Clubman R55 need to idle for 15 min to be able to drive it without stumbling. ECU fault log shows P0112: Intake Air Temperature Circuit Low Input, P0300: Random/Multiple Cylinder Misfire Detected, P1197: O2 Sensor Heater Circ.,Bank2-Sensor1 Electrical Malfunction. MAF,thermostat was changed but problem stayed. Also have noisy lifter. Help Please. Thanks in advance
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Designations (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article |
I would check engine timing. Sounds like possible worn timing components.
- Nick |
Timing chain kits here if needed: 2009 Mini Cooper Clubman Wagon - Camshafts & Timing Chains - Page 1
| All times are GMT -8. The time now is 09:51 PM. |
