-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Oxygen Sensor Tubocharged Engine Replacement (http://forums.pelicanparts.com/mini-discussion-forum/959974-question-oxygen-sensor-tubocharged-engine-replacement.html)
RyMar (guest) 06-13-2017 07:28 AM
P2d0d- Oxygen sensor heating before catalytic converter. I do have 12V supply and ground. Sensor has been replaced. Do you know what the resistance is on the heater circuit?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Turbocharged Engine Oxygen Sensor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 06-13-2017 07:28 AM
No I do not. That info is not published. The DME will be looking at current or voltage drop, not resistance.
- Nick
