My 2004 mini 175K mileshas a year old rebuilt manual transmission, everything worked fine till recently , i could not put into reverse, then when driving forward through gears and stop , i was able to put into reverse, then happened again after driving forward awhile , no reverse..repeat, before the rebuilt transmission i noticed sometimes a little trouble getting into reverse,does this sound like the shifting cables?
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Shift Cable Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article |
it does/. try manually shifting at the levers on the trans. If it goes into gear OK, replace the cables.
- Nick |
| All times are GMT -8. The time now is 11:55 PM. |
