code P1631
Hi i have a 2007 cooper s r56 with code 1631 engine light on.book says throttle valve actuator spring test ,what is this and do i need to replace the throttle valve or just clean it. thanks
P1631 0x28BD/0x2B22 Throttle Valve Actuator Spring Test
Your throttle body could potential be on its way out. I've seen many individuals with this code that replaced the TB and it resolved their issue. TB replacement and info here: MINI Cooper R56 Throttle Housing Replacement (2007-2011) | Pelican Parts DIY Maintenance Article New TB, if needed, here: 2007 Mini Cooper S Hatchback - Intake System - Page 2 |
ok thanks Luccia i wil replace it
| All times are GMT -8. The time now is 09:13 PM. |
