-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Fan Resistor Replacement (http://forums.pelicanparts.com/mini-discussion-forum/966161-question-fan-resistor-replacement.html)
pat (guest) 08-11-2017 08:57 AM
Any opposition to soldering the connectors versus using butt joints? Thanks in advance!
This post was auto-generated based upon a question asked on our tech article page here: Mini R53 Cooling Fan Resistor Replacement | R53 Cooper (2002-2006) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 08-11-2017 08:57 AM
Solder technique varies too much between techs. So butt tends to be best bet.
- Nick
Luccia at Pelican Parts 08-15-2017 02:26 PM
Can always have a professional solder for you.
Dave at Pelican Parts 08-15-2017 03:58 PM
If you have to ask, you probably aren't the right one for the job. If you are a highly-skilled pro, you will know the techniques for getting a good solid vibration-resistant solder connection, and asking would be redundant.
I can solder, but not well enough for an automotive application (read that: High vibration and large temperature swings). So a good solid crimp splice is what I do. And not the cheesy yellow-covered universal splices, either! A decent quality connector of the correct size, fastened on with the proper crimping tool that applies a massive amount of force. And shrink tubing to cover the splice.
Or find a real pro, not some random stereo-installation guy.
--DD
