Hello, I have a 2009 clubman S when I insert the key nothing happens the 'click' doesn't feel the same as it used to. I replaced the key battery and still nothing. If I try this what else will I need to do? I.e reprogram key or ignition etc. if so how would I reprogram the key? Don't have a mini dealer within 250 miles of me.
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Remote Key Slot Replacement (2007-2011) | Pelican Parts DIY Maintenance Article |
if you have to reprogram the key, you will need to find a shop capable of programming MINIs.
- Nick |
Have you tested the battery or pulled any codes from the DME and other systems?
| All times are GMT -8. The time now is 03:28 AM. |
