-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Turbo Engine Fuel Injectors Replacement (http://forums.pelicanparts.com/mini-discussion-forum/966256-question-turbo-engine-fuel-injectors-replacement.html)
Richie (guest) 08-12-2017 06:58 AM
very well written, My son has a 06 JCW that we are having a Misfire on #2 cylinder. I did the usual stuff plugs, plug wires and coil pack... swapped #2 injector with #4 checked compression... used my noid light to check the PWM negative coming from the ECU and got the pulse for a few seconds then it went away, So I suspected the ECU, so I bought a ECU car ran fin for a few seconds then went back to misfiring any suggestions Thank you...
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Turbocharged Engine Fuel Injector Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 08-12-2017 06:58 AM
The injector will be shutdown by the DME is a misfire. What was compression on all four cylinders? First puff and final?e is detected.
- Nick
Luccia at Pelican Parts 08-18-2017 03:02 PM
Did you do a leak down and compression test?
Compression Testers - PelicanParts.com
