-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Crankshaft Sensor Replacement (http://forums.pelicanparts.com/mini-discussion-forum/967745-question-crankshaft-sensor-replacement.html)
shadowfax22 (guest) 08-25-2017 06:51 AM
hello again
so i connect diagnostic when the car was on and i get fault code : Coding is not ok
High Voltage High Pressure Fuel Injector Cyl. 4
High Voltage High Pressure Fuel Injector Cyl. 3
High Voltage High Pressure Fuel Injector Cyl. 2
High Voltage High Pressure Fuel Injector Cyl. 1
Central body - FRM Legroom Module
Chassis sensor signal, front short circuit
Central Body - JBE Coupling Box
that's are all diagnostic faultis
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Crankshaft Sensor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 08-25-2017 06:51 AM
Sounds like a short in the fuel injector harness.
- Nick
Shadowfax22 (guest) 08-25-2017 06:51 AM
Dont have faulty codes, i will check al that you recommend!
Hope to figure it out whats wrong.
let me know what you find.
- Nick
