-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on VANOS Solenoid Replacing (http://forums.pelicanparts.com/mini-discussion-forum/969418-question-vanos-solenoid-replacing.html)
bin (guest) 09-08-2017 06:15 AM
have a 07 plate mini with n12 engine replaced timeing chain and vanos solenoid still got 2845 so replaced the unit on end of cam still same only exuhast cam would a cam sensor bring up same fault
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 VANOS Solenoid Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 09-08-2017 06:15 AM
Is that a P-code or BMW code and what is the fault code description?
- Nick
Luccia at Pelican Parts 09-28-2017 10:23 AM
Did you clear the codes after doing the replacements? I'm assuming you mean P2845? That doens't show up in the Bentley Manual. Are you using a MINI specific scan tool?
