Great tutorial, I'm in the process of replacing my throttle body and used this tutorial as a guide. I do have a question though, what is the part from picture 23 upper right corner and where is its place? I have mine zip tied somewhere under the manifold done by a bad mechanic...
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Turbocharged Engine Intake Manifold Replacement (2007-2011) | Pelican Parts DIY Maintenance Article |
That is the purge solenoid, it attached to a metal bracket under the intake. you can see the bracket in the same photo, look below the intake ports, under the intake.
- Nick |
| All times are GMT -8. The time now is 11:11 PM. |
