-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Coolant Temperature and Oil Pressure Sensor Replacement (http://forums.pelicanparts.com/mini-discussion-forum/969425-question-coolant-temperature-oil-pressure-sensor-replacement.html)
Peter 86 (guest) 09-08-2017 06:24 AM
My Radiator fan stop working, i disconnected the temp sensor and the fan came to live. I thougth that my temp sensor was not eorking and repalce it. After connecting all the wires and start the engine, let it warm up and turned on the ac, and the fan did not start. Does it means i need to change the thermostat?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Coolant Temperature and Oil Pressure Sensor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 09-08-2017 06:24 AM
The low speed portion of fan may be faulty. With no coolant temp, high speed is activated.
- Nick
