Go Back   Pelican Parts Technical BBS > 3- European Cars > MINI Discussion Forum
martinroger (guest)
Guest
Posts: n/a
Hey, I have a non-S 2002 Cooper. Can the harmonic dampener be replaced by the 2004 model rather than the current three-spokes layout ?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Crankshaft Pulley Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 10-29-2017, 06:34 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Good question, I have not done or heard of that swap. The engine block and crank are the same. SO - if the pulley diameter is the same, it should be OK.
- Nick
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Administrator
Luccia at Pelican Parts's Avatar
Why not stick with what you've got? We have your stock one here: 2002 Mini Cooper Base Hatchback - Engine Miscellaneous - Page 1
Old 11-03-2017, 08:44 AM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
