Guest
Posts: n/a
Hey, I have a non-S 2002 Cooper. Can the harmonic dampener be replaced by the 2004 model rather than the current three-spokes layout ?
Thanks __________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Crankshaft Pulley Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article |
Good question, I have not done or heard of that swap. The engine block and crank are the same. SO - if the pulley diameter is the same, it should be OK.
- Nick |
Administrator
Why not stick with what you've got? We have your stock one here: 2002 Mini Cooper Base Hatchback - Engine Miscellaneous - Page 1
